Finally got this done. Here's the DIY I promised.
The Parts you are going to need are:
A4 Engine Cover
(2) WHT000355 Securing Ball/Screw Ball Mfg Part#
(1) 06D103943B Bracket
First take off your stock cover/ airbox. It should look like this.
That is the screw holding in the bracket that needs to come off
I used a long flat head screwdriver and it came out just fine. It wasn't tight at all.
This is what the original bracket(left) looks like compared to the Audi one.
Now, install the new bracket the same way the other one was in. On the left side of the engine all you have to replace is the larger screw holder thing that attaches to the VW cover. Put in your second ball screw and you're set.
Should look like this.
A4 Engine Cover
