#1 |
VR junkie
MAF unplugged = car runs better WTF??
The engine is a COMPLETELY stock '06 2.0T FSI, including factory air box/engine cover.
I've been experiencing a hesitant, rough idle for several thousand miles as well as a CEL. My first thought was coilpacks, but I figured I'd change the plugs before taking it in for the recall. After changing the plugs I started the car back and it idle PERFECTLY. Ran it for about 10 minutes then when I went to shut the hood I noticed I had [unknowingly] left the MAF unplugged. When I plugged the MAF back in the car leveled off at idle, but it was back doing the bumpity idle as before. I restarted, took it for a drive, restarted several times more and the idle continued to be bumpy. I unplugged the MAF again and it ran smooth as a baby's ass again. So WTF is it? The ECU must be reverting back to a base air/fuel map or utilizing different sensors when the MAF is unplugged. So, bad MAF? |
#2 |
![]() Drives: 2008 Gli Fsi Join Date: Apr 2009
My guess would be a bad maf sensor.
#3 |
MA emissions Inspector
Do you have a code from the CEL?
Ext Mod:Konig Hot Swap w/ 225/40R18 Bridgestone Potenzas - Rieger rear skirt - Nokya hyper yellow fog bulb. Int Mod: Newsouth offset dash pod w/ turbo boost, oil pressure and temp Performance/Handling Mod: AEM fcai - APR KO4File (full ECM) - Autotech 4 piece braided brake line kit, front & rear pad/rotor kits - Evolution Motorsport Engine cover and heat shield - Forge FMI, switchable b/o valve & diverter valve - GHL 3" Turbo back Quad tip exhaust - Koni FSD Eibach suspension kit - Neuspeed 25mm rear sway bar, Hi-Flo Intercooler pipe & Turbo Discharge conversion kits. BSH street catch can. |
#4 |
Lasers go Pew Pew
![]() Drives: 2K6 BMP GTI & 93 MR2 Turbo Join Date: May 2007
do you experience rough starts as well? ie taking a long time to start or turn the key, no luck turn again and it fires up kind of rough?
#5 |
FIA World Rally Car Champion
![]() Drives: mk5gti, b5s4, fz1 Join Date: Nov 2009
intake leak, vacuum or charge.
#6 | ||
VR junkie
I was gonna wait until I get back from vacation to purchase a VAG-COM ...no money at the moment. I have some friends in Houston w/ VAG-COM but that's 3 hours away and I don't have the time. The bumpy idle has been around MUCH longer than the CEL
What do you mean by 'charge'? How would any of these be overcome by unplugging the MAF? |
#7 |
Radioactive Rotary Rocket
![]() Drives: '95 Ẽfini RX-7 Type R Join Date: Jul 2009
Yeah it could be a vacuum leak, charge would just be it leaking under boost.
It could also be a bad MAF sensor. Diagnostics would help a lot on this one. |
#8 |
![]() Drives: 07BMP GTI 6MT/2010 DGM STI Join Date: Aug 2007
if you have a boost leak or vac leak the car is seeing x air going into the motor at the MAF. If it is leaking after the maf the a/f mix will not be correct. If you unplug the maf the car switched to map based mode and reads air quantity and calculates the amount of fuel to be delivered by the pressure in the system. The map sensor is mounted on your throttle body pipe. so if the leak is before there and after the maf this is why unplugging it would help.
Also like its been said could be a faulty maf but best way to try without diagnostics on hand is swap mafs with a buddy real quick and see if the problem still persists. |
#9 |
![]() Drives: '08.5 Gray m/t Wolfsburg Join Date: Oct 2008
If unplugging the MAF helps the situation, it is usually the MAF sensor itself. Well, at least on MAF-only vehicles without additional MAP sensor, such as my 1998 Volvo C70.
'08.5 Jetta Wolfs CBFA Plat Gray/Anthracite M/T Vogtland 1.6" Springs, Bilstein Sports, VF dogbone, 42DD shift bushings, Neuspeed FMIC, APR DP, Autotech catback, Tiguan pipe, BSH true seal 1+2, APR stage 2(+) |
#10 |
Formula 5000 Champion
![]() Drives: too high Join Date: Oct 2008
The MAF sensor is only screwed into the whole engine cover/airbox. You can separate the sensor from the engine cover.
I wonder if mine is bad...I've been getting a pretty annoyingly rough idle for almost the whole time I've owned the car. I've gotten a couple of unexplained CELs, but they've all cleared themselves.
#11 | |
VR junkie
Is it possible for the leak to be substantial enough to cause a slightly bumpy idle, but still insignificant enough to not register any difference on my boost gauge? I think it's humorous how I've been running a boost gauge on a stock GTI for 3 years, but it's the one thing I wanted on the car right off the bat (for reasons such as diagnosing problems such as this one). With all the PCV and DV problems out there I don't know how some of these guys can run a chipped car w/o a gauge. BTW, thanks for all the responses and help guys, it's much appreciated. |
#12 |
![]() Drives: 09 2.0T 6MT Join Date: Sep 2009
I have an 09 GTI with 6000 miles and Ive noticed a bumpy idle since I bought the car at 180 miles. now its way worse, feels like the car is going to die. but the RPMs dont move, and no CEL's. I haven't checked with the dealer yet but Im sure they're going to say nothing is wrong. They recently replaced the 02 sensor due to a CEL. forgot to mention my car is completely stock.
#13 |
Speed>stance
![]() Drives: c2 turbo bunny Join Date: May 2007
VW MAF sensors can be had for as little as $80 if you don't mind buying an a1 cardone reman, usually special order at the O'Reily's or autozone. the above mentioned price is for a rabbit MAF at O'Reiley's
-2007 Rabbit 2.5:::Denvers: smoked clear sides: Textured GTI rear lower: Magnaflow exhaust: Techtonics High Flow Cat: Podi Boost Guage: VEI Dual Display Gauge Oil Pressure/ AFR: C2 Stg 2 turbo: Turbo XS MBC: Forge 007 DV : o2j swap: Quaife LSD: Southbend Stg 3 clutch, single mass flywheel: AEM w/m kit: BSH mounts : EBC Yellowstuff pads |
#14 |
John...
![]() Drives: Seat Leon Mk2 1.8TSI Join Date: Aug 2009
Hi @ all....
I have the same problem with my chipped 1.8TSI... with MAF it is running much rich and I have some missfires... without MAF the car is significantly faster... I dynoed with and without Maf and I have 243 BHP with 372nm with MAF and 239 BHP with 380nm without MAF and never had any missfire without MAF!!! see the dynos... left is with MAF, right is without MAF ![]() and here both...
e-tuners, apr i/c, 3"dp with 2,75" catback, dyno 294 BHP / 510 Nm, APEX/Bilstein B8, 18" Audi R8 wheels, S5 brakes, forge boost pipework, forge DV and bsh stg2 intake, soon forge wga+yellow spring
#15 |
Ever heard of closed loop mode? At WOT the ECU ignored the MAF and oxygen sensor and runs preset fuel tables. |
#16 |
John...
but why it runs without MAF better in midrange???
With MAF I have an AFR of 10,4:1 from 2000rpm to 7000rpm. without MAF I have AFR 11,4:1 from 2800-4500 and then AFR of 10,8:1 from 4500 to redline!!!
#17 |
VR junkie
I agree ...at WOT the engine is running a preset map.
I really need to buy an VAG-COM, but I just can't cut it right now. Anyone in the Austin area have one? |
#18 |
#19 |
VR junkie
Today I found out the car is misfiring on cylinders 1,2, and 3. Spark plugs were replaced about 2k miles ago. Stealership appointment tomorrow @ 9am for coilpack recall.
If the coilpacks WERE the cause of it all, how would unplugging the MAF make a difference? |
#20 |
Oval Newbie
![]() Drives: 1986 mustang lx Join Date: Dec 2009
OP have you cleaned the MAF? Maybe some how the wire got dirty and with it unplugged it reverts to a preset fuel table. It can't hurt and the can of MAF cleaner cost like $2.99
#21 |
VR junkie
No I haven't tried that. My plan is to borrow a MAF from a local if possible, to see if it's responsible for all of this.
#22 | |
John...
| Thread Tools | |
