black forest ind
- Cary, North Carolina
- All of them
Black Forest Industries is proud to announce the release of our newest product line:
The Clean Catch Crankcase Oil Separator, the most advanced, most functional and best looking option to remove excess oil vapor from your PCV/Intake tract.
One of the biggest concerns of the direct injection engine design - is what to do with crankcase vapor. As with all emissions compliant vehicles, the PCV gasses must be recirculated back into the intake tract. The problem with direct injection is that those latent oil vapor laden gasses then help with the process of carbon deposition on the intake valves. For many who have experienced this, you will be familiar with valves that look like this:
Help to limit those deposits by removing as much of the oil vapor from the PCV system as possible with one of our Clean Catch catch cans!
For the Mk5 there are two different versions for each 2.0T engine - for the FSI engine ('05-'08.5):
Click the picture for pricing and info!
All FSI Clean Catch catch cans utilize our new VAGPORT PCV connection system and come with pre-crimped #8 hoses, fittings, brackets and all necessary hardware for installation in minutes! Each Clean Catch FSI catch can is designed to fit under the factory airbox/intake as well as the factory "noise pipe"
And a version for the TSI engine ('09+):
Each TSI Clean Catch catch can utilizes our new VAGPORT PCV connection system and comes with pre-crimped #10 hoses, as well as all fittings brackets and hardware for installation in minutes! Each Clean Catch TSI catch can is designed to fit under the factory air cover and utilizes the same type of quick release connector used by Audi Sport and Team Joest on the Audi Le Mans prototype cars. *At this time we do not have a version that is compatible with the stock "noise" pipe*
