#1 |
Rally Car Newbie
![]() Drives: VW R-Line CC, C300 Join Date: Sep 2008
K-Sport Front endlink spec
got the endlinks today and the specs are
Rod Diameter 16mm - Stock 10mm Total length 305mm-355mm - Stock 335mm about 20mm/0.8 inch up or down hopefully it has enough adjustments for my coils
#3 |
FIA F1 World Champ..to be
![]() Drives: 2009 BMP GTI DSG Join Date: Aug 2009
Nice! I have been curious about these!
Think very carefully, because if you ever start, you will never be able to leave it alone.
#4 |
Radioactive Rotary Rocket
![]() Drives: '95 Ẽfini RX-7 Type R Join Date: Jul 2009
Yay you finally got it. Now you can put the swaybar back on. At first I thought this just an OEM swaybar end link that is chopped, threaded, anodized, and put in a tube, but then I saw it's completely different even at the ends.
#5 |
FIA World Rally Car Champion
![]() Drives: CW gti07mkv Join Date: Apr 2008
how did it turn out?
#6 |
Rally Car Newbie
@ almost 1k miles so far so good, no noise at all and it doesn't look like it's going break soon.
#7 |
Formula 5000 Champion
![]() Drives: 2006 GTI DSG Join Date: Nov 2010
I have koni coilovers currently and am getting a lot of swaybar clunking. Would some shorter endlinks solve this dilemma?
06 GTI DSG --- Eurodyne Comp5858 DSG fully built (IE, Wossner, Ferrea) 562whp and rising. 11.3 @126mph (1st pass of 2012, 10s to come) VAG-COM for beer in Maryland
#8 |
Rally Car Newbie
from what I know, If you have an after market sway bars you need longer and stock bars shorter to get rid of the clunking noise.
This endlink will work on both since it can be longer or shorter. Hope it helps. |
#9 |
Yup...ty.
Sent from my SPH-D700 using Tapatalk
#10 | |
╭∩╮(︶__︶)╭∩╮ haters
![]() Drives: 2009 VW GTI BMP Join Date: Sep 2008
front or rear?
![]() ::APR stage2::BSH -Race Intake,Mounts,TB Pipe,RSB::Eurojet v1.0 DP::Whiteline -A.L.K.,Endlinks ::Devils Own DVC-30::Neuspeed -Brake Lines,R32 catback::BC Racing BR coils::Unibrace -xB & uB ::OSIR::Flik FTD::245x40x17::Alpine PDX5::Uber Stealth Audio 10"::Bildon Wheel Studs::Hawk HPS Read this for TSI INFO/FAQ |
#11 |
Front. I have some shorter fk endlinks at home but haven't put them in yet. Also...coilovers are al the way up, as in raised.
#12 | |
FIA GT Newbie
![]() Drives: 06 GLI Join Date: Jan 2008
Don't waste your hard earned money on APR Stage 3 kit look here. http://forums.vwvortex.com/showthrea...ge-3-dyno-runs |
#13 |
FIA GT Champion
![]() Drives: 07 2dr VW GTI Join Date: Jan 2011
How are these holding up for you?
MODS: APR RCS TBE | Revo stage 2+ | BSH Trueseal | BSH Bulletproof DV fix | BSH PCV fix | Koni Yellows | Eibach Sportlines | HPHF Upgrades Stage 1 | 142bar Fuel Rail Valve | BSH Front mount IC, BSH Dog Bone mount, BSH Throttle Body Pipe, H&R 28mm front 24mm rear swaybar, Whiteline Anti-roll link kit KLC167, Avant Garde M310 | Continental DW. |
#14 |
APR Stage II+
![]() Drives: 2008 BMP GTI Join Date: Jul 2009
I've had these for over a month.. no problems.
![]() 3M | Air Lift | APR | AWE | BSH | JL Audio | Kenwood | KSport | Neuspeed | NGK | Nokya | VF Engineering | Votex
#15 | |
atom heart
![]() Drives: GTI Mk.V 2008 2-d Join Date: Mar 2011
End link length doesen't change 'preload' cos there isn't any 'preload' on a sway bar. (otherwise than caused by different length end links left/right) The only think I'd use adjustable end links is if I need space (sway touching control arm) or to help adjusting cross weights.
BBS, Ferodo, H&R, OEM VW + TT, S3 & RS3 parts, aerodynamics, Sachs Performance, Supersprint, SuperPro, Tarox, Whiteline PICS |
#16 |
FIA GT Champion
Just trying to resolve the clunking from the factory sway bar links.
#17 |
atom heart
Got these today:
![]() ![]() http://www.whiteline.com.au/product_..._number=KCA314 http://www.whiteline.com.au/product_...sans_vehicle=1 http://www.whiteline.com.au/product_...sans_vehicle=1 ![]() First impression: looks and feels very very solid !! the K-Sport (from the pictures - never had them in my hands).
#18 |
SteelCities-SCCA AutoX
Ooo whiteline bump-steer kit! let us know how that goes!
#19 |
APR Stage II+
What does the bump-steer kit do?
#20 |
atom heart
Changes steering/toe curve and improves steering under cornering loads and bumps esp. on lowered cars.
Differing to the pics my kit came with black sleeves to protect them from salt and water. http://www.whiteline.com.au/product_..._number=KCA314 "KCA314 is designed to correct the geometry of the front to reduce bump steer and provide accurate steering precision. Bump Steer is when your wheels steer themselves without input from the steering wheel. The undesirable steering is caused by bumps in the track interacting with improper length or angle of your suspension and steering linkages."
BBS, Ferodo, H&R, OEM VW + TT, S3 & RS3 parts, aerodynamics, Sachs Performance, Supersprint, SuperPro, Tarox, Whiteline PICS Last edited by the bruce; 04-04-2012 at 05:51 AM. |
#21 |
FIA GT Champion
Did you buy the whitelines from their site for the 167.00?
MODS: APR RCS TBE | Revo stage 2+ | BSH Trueseal | BSH Bulletproof DV fix | BSH PCV fix | Koni Yellows | Eibach Sportlines | HPHF Upgrades Stage 1 | 142bar Fuel Rail Valve | BSH Front mount IC, BSH Dog Bone mount, BSH Throttle Body Pipe, H&R 28mm front 24mm rear swaybar, Whiteline Anti-roll link kit KLC167, Avant Garde M310 | Continental DW. Last edited by GTIRaider; 04-04-2012 at 01:58 PM. |
#22 |
FIA GT Champion
nvm i found them for 149 here
http://thmotorsports.com/i-521840.as...ingSeanVehSpec
| Thread Tools | |
