#1 |
Touring Car Champion
![]() Drives: MKV 09 GTI Join Date: Jan 2012
Official GSTOCK autox thread
OK guys lets pool together some knowledge on the GTI in stock class. I know tons of people have their car way over prepped for such a class but some of us do like the idea of trouncing people in a stock car.
My Previous car and setup 2009 Civic SI sedan 245/45/17 Star specs stock wheels 245/45/17 Hoosier a6/ TDR racing wheels 17x7 k&n drop in HFP shocks this set up alone was enough for me to win almost every local event in my area ( NC autox championships got me 3rd.....) Now the GTI can be very capable of doing well in stock class in local and regional regions but its does have tough competition ( Civic Si, SRT4, and if the mini is being moved up from HS) Current set up (STOCK) PLANS -2009 GTi -245/40/17 Hoosier a6 or Kuhmo V710(they last longer) Rcomps -Possibly 245/40/17 star specs to run in the new national street tire class -Big front sway ( the car rotates just fine it needs to keep flat have more contact to the road during turn in and its steering ratio isnt as quick or doesnt feel as a good as the others) -koni yellows ( obviously... this car is pretty well set up from the factory but lets face it the stock dampening rates are pretty soft and lateral transition is key in autox) So chime in fellow stock classers!
#2 |
I brake for apexes!
![]() Drives: Front Rear Sport Join Date: Feb 2008
I've never run GS only STX but don't you need to keep stock tire size in stock classes?
And I doubt you'd get those R-comps that are that large to fit even with the sky high stock suspension. |
#3 | |
I need to run the biggest tire i can. GRIP>RESPONSIVENESS also i meant to post 245/40/17s for the future setup |
#4 |
FIA World Rally Car Champion
![]() Drives: 2005 S2000 Join Date: Aug 2008
Rear bar will be faster.
It would be much much better to control the front via shocks. The Konis are a good start, but as you develop the car you may want to consider a shock that can put out significantly more force than a yellow. Especially on compression where the Koni has very very little.
![]() 05 S2000: Moton Clubsports 800F/600R - Berk Technology - Gendron FSB OLD MKV GTI:TD Pro Race 1.2 - 255/40/17 Dunlop Star Specs - AST 4100s w/Vorshlag Camber Plates - APR RSB - Hawk HP+ pads - GHL DP w/cust. catback - EVOMS CAI - APR Stg 2[/size] GO>SHOW |
#5 | |
#6 |
The Konis are a great entry level option, and can get most the job done. Especially on cars already well balanced like an RX8.
However the GTI is far from balanced and very heavy. In stock class where you cannot change springs the shock forces are often used to act as stiffer springs to control body roll far more then they are asked to do in say an ST class like STX. I would talk to AST/Moton, True Choice or Performance Shock about what type of options they could do for a GTI. If you explain that you are planning on running competitive stock class autocross then they should know what type of valving you may need. I know Brian at AST and he is very knowledgable and would be able to find you a reasonably priced solution especially with the new double digressive piston they have developed from the Grand AM cars.
#7 |
SteelCities-SCCA AutoX
Look into getting some lighter stock size wheels too. I think stock wheels are 7.5" in width right? RPF1's are an exact match and they are really effing light. Remember you get +/- 5mm on your offset too. Get a catback too and cut down on weight.
Wish I could have kept mine stock as I think GS is the best class for our car. The new street tire class seems pretty cool but aren't the rules kind of weird? Like won't you be racing FWD cars outside your class or something? |
#8 |
Ohh also brake lines, super blue fluid, and pads too.
#9 |
#10 | |
#11 | |
I brake for apexes!
#12 |
245 Hoosier does not exactly equal the width of a 245 street tire. I would buy one of the Hoosiers to test fit or find someones take off.
#13 | |
Formula 5000 Champion
![]() Drives: 2008 GTI, 1995 BMW M3 Join Date: Mar 2007
I think a big front bar works great on these cars, you'll find you won't need so much front camber with a stiffer front bar setting. Cars stays more planted and much better turn in. As always test first.
PCA HPDE Instructor (#62 United Grey 2008 GTI) E Plebnista |
#14 | |
Boston, know any good places to find them though? Checked out Turner motorsports but they had lots of one offs. |
#15 | |
#16 | |
Racing is a rich mans sport that attracts poor people |
#17 |
Autocross Newbie
I have a couple of questions, since I haven't autoXed yet, but am looking into starting. In order to stay in the GS class, an intake is a no-no, correct? The only other performance mod I have is a tune, and I feel like a tune + intake wouldn't make me very competitive in the next class (I think I'd switch my BSH intake out before I run). Also, would a dogbone mount insert not be allowed for GS?
Also, what would be the best brake pads to run for autoX + the street? Is there such a pad? and if not, is it safe to switch out pads from performance to street?
<-- Mods in garage. |
#18 | |
I run EBC Yellowstuffs, had them on during the winter here in Pittsburgh didn't have any issues. I think they are a pretty good all around aggressive pad. Anyone here ever run brakes from Porterfield? Noticed SCCA members get a discount on them. I think I read a comparison article on them once and they turned out pretty good there. |
#19 |
Autocross Newbie
Cool, thanks man. I just wasn't sure if they'd put me in a class the first day, or how it works at all really. I'm actually headed to Pittsburgh for the summer... it seems like theres a bunch of places out there that do autocross.
#20 |
That's awesome! We have a pretty solid contingent of VW autoxers up here of at least 5 or so. There are two different clubs, one is NHSCC and the other is Steel Cities which is SCCA. They kind of race at different times in the year so there is a lot of oppurtunity for wheel time. We also have a mini forum where a lot of local racers hang out called Racepa.com. I have the same name there. Let me know when you move and you are ready race! Season starts next month!
#21 |
first event with the GTI next week. cant wait to see how it compares to the si and the mini
#22 |
created and printed out my own log book. this season is going to be different than the previous as now that all the basics have been covered and my driving skills have advanced. I can start focusing on the numbers game and being able to go 10/10ths every run instead of having a few half paced runs then going all out. I placed first in 90% of the events i did last year and that was never really my goal to win my class. I always wanted to be top 10 FTD. This car will definitely be a handful to get to that point but i look forward to improving my skills this weekend.
side note whats everyone doing for alignment settings on the mkv? the civic was -.7 front -1.0 in the rear, 0 toe in the rear and 1/8 toe out in the front. |
| Thread Tools | |
