#1 |
IMAGE IS EVERYTHING.
17" Wheels, 18ZL/350MM, No modifications, No problem!
So, lots of people thought there isnt a 17" Wheel that clears the 18ZL Calipers.
Found one! ;) Rays Engineering Volk Racing TE37. Mine are off an S2000. 17x9 +65 with 30MM Front Adapters and 25MM Rears. Final Specs: 17x9 +35 17x9 +40 245/40/17 Dunlop Direzza Z1 Star Specs. I have tons of clearance to the spoke, probably a good 15MM. I also have a few MM from the closest calipet point to the barrel. Will need to likely mount the wheel weights on the BACK side of the wheel, though i havent tested with the weights mounted on the spoke-side. Keep in mind, thr TEs run a 12x1.5 Bolt Hole, so youd have to drill them out to 14x1.5. There should be a few more. Some CCWs work, and ive been told some ADVANs. I have access to a set of ADVAN RSs, so ill give it a shot and take some pics too :) Here are the pix! :) ![]() ![]()
#2 |
SteelCities-SCCA AutoX
Absolutely splendid wheels. Looking good!
Good news that you clear the larger brakes! How is the clearance with the +35 17x9's up front with things like the springs/shocks fender liners. Please say tons of room, haha. I'm interested in stepping up to wheels this wide but would like to run a larger tire like a 265. |
#3 |
Not a chance will you squeeze a 265 in there.
I have maybe like 7MM From the Front Strut, and the 245s were really pushing it on OEM Fenders. Here they are on the SRS-TEC Wide Fenders (+25MM) ![]() I mean, you want a 265, I don't thikn that'd happen. Depends on the height you drive at I guess, it'd poke a fair amount. Do you have front camber adjustment? |
#4 |
Rally Car Newbie
![]() Drives: 2007 BMP GTI Join Date: Feb 2011
This makes me want the SRS-TEC fenders... stopthat
J€RMÅNESE Åutø |
#5 |
N/A
![]() Drives: 2008 GTI Join Date: Jun 2008
Finally. Gj phil. See you at the track this year :)
#6 | |
#7 |
![]() Drives: 2007 MKV GTI 5dr Join Date: Mar 2012
Looks awesome!
What adapters did you use? Do they have different sizes to help with the tire fitment issue? |
#8 |
Rally Car Newbie
These just might do it too:
17x9 +48 or +63 ![]() 949RACING 6ULR
J€RMÅNESE Åutø |
#9 | |
Order them!
![]() Quote:
I also threw a 5MM Spacer on top of the Adapter to give it a bit more clearance to the Bag. Makes me feel better about it, haha. Hmm. Not sure. It's all about the inner diameter. I know CCW makes some that clear, and apparantly, TireRAck's own Wheel Brand "TR Motorsports" also has a set that'll clear. Lightweight and cheap too, might be worth looking into. There's also a few ADVANs that'll clear, not the RSs though I don't think. Though i'll test that out and let people know, |
#10 |
Rally Car Newbie
Trying not to dump any more money than necessary in this bucket
J€RMÅNESE Åutø |
| Thread Tools | |
