#1 |
kenneth
![]() Drives: 2006 GTI MKV Join Date: Dec 2010
Cam follower help, cant take off
I have problems removing the banjo bolt on the hpfp, ive read and tried all ways on the DIY and it wont come off!
Can the dealer replace that bolt or fule line with something easier to take off? |
#2 |
![]() Drives: golf 5 gti dsg 2007 Join Date: Apr 2012
why are having difficulties...which bolt is it?
i noticed that if you let the car cool down for too long the bolts are harder to come off. |
#3 |
FIA World Rally Car Champion
![]() Drives: 2010 CW Jetta TDI Join Date: Sep 2011
I changed my cam follower without any trouble with bolts. maybe just needs some more elbow grease
UroTuning.com |
#4 |
kenneth
The bajo bolt one, the one kinda hard to get in it just wont come off :/ idk if its the wrong size torx im using?
#5 |
FIA GT Champion
![]() Drives: Mk5 Golf GTi Join Date: May 2008
#6 |
kenneth
How much would the charge be for this? I have some recalls from VW might as well replace them cause i cant check my cam follower.
#7 |
FIA GT Champion
It's reasonable easy to do.
I bought the required updated fuel lines and rubber hoses off of ebay for less than $40. All you'll then need is the bamboo connector that you use to replace the banjo connector on the hpfp. |
#8 | |
Autocross Newbie
![]() Drives: 2006 GLI K04 Join Date: Sep 2011
K04 - Unitronic Stage 2+ - S3 Injectors - Stage 1 hpfpupgrade.com HPFP - RS4 Rail Valve - Neuspeed Intake - Golf R Intercooler - Eurojet 3" Catted Downpipe - BSH PCV - AWE DV Relocation - KSport Coilovers - Whiteline Lower Control Arm Bushings |
#9 | |
kenneth
![]() Do you have a pic of the updated fuel lines on yours? |
#10 |
Another Addict
![]() Drives: '06 White GTi 6spd Join Date: Jul 2011
Well I posted on the DIY that's stickied how to check the CF without taking off the banjo bolt...It is a PITA. but with some strength and persistance you can free it up...
#11 |
an hero
![]() Drives: 2006 Deep Black GLI Join Date: Sep 2009
A dealer will charge upwards of $600 for the new fuel lines to replace the banjo bolt system.. $280ish for parts and $3-400ish labor(requires R&R of intake manifold). Not worth it imo, once you figure out the banjo bolt it gets much easier to do the next time.
#12 |
kenneth
Ill give it a try one more time, what it the size for the triple square?
#13 | ||
Autocross Newbie
#14 |
Touring Car Champion
Just replaced my CM and that bonjo bolt was a pain ti the ass! I the end I got it done and felt good about it...
APR Stage 1/BSH Catch Can/BSH PCV Fix/Neuspeed P-Flo/DV Rev D... |
#15 |
Newbie
![]() Drives: A white turbo car. Join Date: Jul 2006
#16 |
![]() Drives: 2006 MKV Join Date: Jul 2012
I use a snap on 1/4 inch fine tooth swivel head ratchet, a six inch extension and a 1/4 universal socket. Tape a 8M triple square bit into the socket. This setup seems to be the best way to get to the banjo head for me. Once you do it you will figure out its really not that big of a deal. It really isn't worth the effort to change out the fuel line, its just tricky the first time through.
#17 |
FIA GT Newbie
![]() Drives: 2008 GTI Join Date: Mar 2012
I would seriously consider picking up the parts and doing the line swap. It took me literally 10 mins to pull my fuel pump and cam follower when I replaced mine.
When I first read the DIY on it, I didn't realize that it was only pre 08's that had the banjo bolt and I was pissed because I had to go buy some stupid ass tool for a simple job lol. But ya, rubber lines ftw!
BUY MY GTI!! ///2008 FSI GTI | APR Stage 2+ | 3" Catted DP/Custom Straight pipe | AEM Boost Gauge | BSH Comp Catch Can | Raceland Ultimos | |
#18 |
Reefur Madness
![]() Drives: 08 VW GTI & 01 Jeep Wrangler Join Date: Nov 2011
Lefty Loosey Righty Tighty!
| Thread Tools | |
