EDGEMKV
Legen-dary
- United States
Alright, I have what I think is a strange issue. From the passenger side, I hear a clicking noise (sounds like plastic not metal). It's constant (a little after start-up) and happens every time I'm at a complete stop or when the RPM's drop below 1,000 RPM's.
Now here's the kicker, if I'm at a stop and slightly press the accelorator just a tad to bump it closer to 1,000 RPM's the noise stops completely. Also, if I turn on my heat or A/C the noise stops completely. I've tried locating the noise while under the hood, and I can't really make out a location, I just hear it more so from inside the cabin.
Has anyone else experienced anything like this? My first solution was to maybe adjust the throttle a tad, but I don't have the necessary equipment to do that. (Assuming it can be done via VAG-COM or whatever.)
So yeah I'm stumped on what could be causing this.
