#1 |
Touring Car Newbie
What's your track brake setup?
Hey guys,
I'd like compile a database of "successful" brake setups you use regularly on track. Please post your: Car and its weight and power Rotors Calipers Brake Pads Min wheel size Cooling You can also add a blurb on your experience level, tracks, conditions, anecdotes if you like. Thanks!
APR Stage II |S3 Intercooler|Carbonio Intake|UR DP|Neuspeed TOP|Hotchkis FSB/RSB|Bilstein Sports|DG Springs|S3 Spindles|W.A.L.K.|StopTech BBK |
#2 |
atom heart
![]() Drives: GTI Mk.V 2008 2-d Join Date: Mar 2011
car - 2008 Mk.V GTI
weight - ~ 1300 kg power - stock 200 HP rotors - Tarox F2000 / stock size 312 mm calipers - stock Ate with brake stiffening kit brake pads - Ferodo DS Performance min. wheel size - stock cooling - RS3 vent + dust shields removed ABS etc. - emergency stop assist set to '02' tirers - Federal 595 RS-R tracks - several auto-X + Nürburgring Nordschleife (no GP circuits) experience level - frequent auto-X + some Nürburgring No fading, no issues. I guess this won't be sufficient for longer stints on a GP track. I will surely swap to Endless MX72 next. ps: others might copy the scheme
BBS, Ferodo, H&R, OEM VW + TT, S3 & RS3 parts, aerodynamics, Sachs Performance, Supersprint, SuperPro, Tarox, Whiteline PICS Last edited by the bruce; 06-12-2012 at 05:51 PM. |
#3 |
Formula 5000 Driver
![]() Drives: 07 4dr GTI, 07 2dr Rabbit Join Date: Jul 2008
car - 2007 Mk.V 4dr GTI
weight - ~fat power - 460whp rotors - 2 piece 330x32 fronts. stock rears calipers -17z 6 pistons. stock rears brake pads - Porterfield R4S all around min. wheel size - 17" OZ track. 18" OZ street cooling - RS3 vent + dust shields removed ABS etc. - emergency stop assist set to '02' Tires- street-255ps'2....track 245RS3's tracks - couple local tracks experience level - intermediate No fading on street. obviously. I get a low pedal after several 20 minute sessions at a fairly high speed track. Added RS3's vents this year. Going to try some higher end brake fluid.
2 X $$ pit. Last edited by cruizin01; 06-12-2012 at 09:39 AM. |
#4 |
![]() Drives: 2011 VW GTI DSG Join Date: Jul 2011
car - 2011 GTI DSG
weight - ~ 1300 kg power - ~ 265 bhp (GIAC Stage 2) rotors - Stock calipers - Stock with TyrolSport brass bushings (front) brake pads - Hawk HP+ (front) Stoptech 309 (rear) min. wheel size - stock tires - Hankook R-S3 cooling - dust shields cut down, RS3 vents (on order) ABS etc. - ATE Super Blue (this year, VW OE DOT 4 last year) emergency stop assist set to '02' tracks - Ste-Eustache (Montreal), Calabogie (Ottawa), Shannonville, Mecaglisse (Tremblant) experience level - lapping since 2006 (still slow :p)
2011 VW GTI DSG GIAC Stage 2, Ultimate Racing DP, Neuspeed P-Flo, DG Springs, RS-3 brake ducts, R20 tails, etc... Last edited by Deaks2; 06-12-2012 at 03:24 PM. |
#5 |
SteelCities-SCCA AutoX
Cruizin01 - How do you like the R4-S? I'm going to be giving them a try next month.
#6 |
Car - 2008 Mk.V GTI
Weight - 3200lb? Power - Stage2+K03 250hp? Rotors - Adam's Slotted AR Race Rotors 312mm Calipers - Stock Ate with Tyrolsport brake stiffening kit Brake pads - EBC YellowStuff Lines - Goodridge SS Wheel size - 17x8.0" ET45 TSW Nurburgring ~18lbs Cooling - dust shields removed Fluid/Misc. - ATE Super Blue Fluid + Emergency Stop Assist set to '02' Tires - Kumho Ecsta XS 245/40/17 Tracks - Pittsburgh International Race Complex, AutoX Experience level - Frequent auto-X + Time Trials since 2010 (Intermediate/Advanced) I've only done the dust shield delete recently so I can't really judge if it made a difference or not. The fluid was fried anyways. With the shields on ATE Super Blue definitely cannot stand the heat. I would get definite fading on track especially towards the end of the day. The car would still stop though it was very unnerving. The Adams rotors are holding up very strong, there is no lip at the top of the rotor so maybe the pads were just a perfect fit? My rear pads are fried after only 1 year of abuse, which consisted of two track days and autox. Last edited by GTI_Speed; 06-12-2012 at 09:38 AM. |
#7 | |
Formula 5000 Driver
Sent from my Galaxy Nexus
2 X $$ pit. |
#8 |
Touring Car Newbie
Good info, guys, thanks a lot.
I was prompted to get this together because last weekend my brakes overheated so i'm looking for new options. I ran Carbotech XP10s front and rear, ATE Type 200, all else stock. (dust shields on) The pads would fade toward the end of each session. My final session was only 25min after the previous and while out they over heated and i lost the brakes. Ended up blowing through T1, but fortunately we were running the infield chicane in stead of the nascar oval so i just skipped the chicane and went up the oval. The pads were smelling and smoking like crazy, much more than anything i've seen before. I thought they might even be on fire but i dont think they were. Also burned the paint off my calipers. My next step will be to take the dust shields off and probably try some Hawk DTC-60s up front. I've had lots of good luck with Hawk HT-10s in the past, and i hear these are even better. When i find success i'll add it to the list. Oh and i'll also sync up this list and the list on mk6.com as well.
#9 | |
Also anyone with overheating issues tried any of the titanium shims to see if that cuts down any heat? |
#10 |
Touring Car Newbie
The shims will cut down on heat transferring to your caliper pistons and fluid, but it will actually retain more heat in the pad/rotor since the heat can't transfer to where it did before.
#11 |
N/A
![]() Drives: 2008 GTI Join Date: Jun 2008
My car is gone now, as I 've moved on, but here are the specs to my Old GTI
Car and its weight and power 2008 GTI, 3200 lbs? Stock ecu, TBE, Twintake, AWE relocate.. around 200? Rotors 328MM 2 piece Calipers stoptech St 40 4 pistons Brake Pads HP+, then HT10s Min wheel size 17 x 7.5 et 43 or 17x8 et 47 Cooling: stock No problems with cooling what so ever. Went around Shannonville Motorsport park, a 4.2 ish km track for about 20 laps and no cool down required still. |
#12 |
![]() Drives: 2010 GTI, 2004 Z06 Join Date: Jul 2006
Tires contribute massively to braking performance, so I added that as well
car - 2010 GTI weight - ~ 3100lbs I think power - Stage 1, 250ish hp rotors - OEM calipers - OEM, SS lines brake pads - Carbotech XP10 in front, XP8 in rear Fluid - ATE Super Blue min. wheel size - OEM Tires - Hankook Ventus RS-3 cooling - Dust shields removed tracks - Watkins Glen, Mont Tremblant, VIR, Lime Rock, NJMP, Summit Point, Monticello experience level - Tracking since 2006, made instructor in 2010 I have just basic brake mods, the cornerstone being the race pads. I think this setup will be good enough for 90% of everyone who takes their car on any track. However when you start getting real fast and have driven a lot of cars on track, you'll appreciate the benefits of a big brake 4-6 piston setup. When I get out of my dad's Z06 or my brothers new Mustang GT with Brembos and get into my car it's like "Hey, where's the brake pedal?" But, the car always stops time after time and it's rare that someone out brakes me after a long straight. So while the stock setup is not race car solid, it is more than adequate for most of what anyone could need certainly on the street and with a couple changes generally on the track.
2010 Black GTI APR Stage 1:://::USP Brake Lines:://::Carbotech XP10/XP8:://::ProSport Boost Gauge Proud ACNA Instructor |
#13 |
Touring Car Newbie
^That's a great data point, thanks. Tires are also a great thing to add to the "sheet".
Interesting that I seem to have completely toasted my XP10/XP10 setup at NHMS. Only difference is that i still have my dust shields. I've heard NHMS is rough on brakes, so i guess its either that or or the dust shields. Is all the paint burned off you calipers? I'm going to swap out the track pads this weekend and i'll be sure to make sure my piston seals are in good shape.
#14 |
Yes my calipers are a nice dusty grey color at this point! And definitely remove the heat shields - those things toast your inner pads real quick. Also, if your 2010 is a MKVI (like mine) then the non-defeatable ESP will also destroy brakes if you're driving the car with any slip angle whatsoever. Well, maybe not whatsoever but the car won't take much angle at all before the ESP starts riding the brakes through the turns at various spots on your car. I roasted a mostly-new set of XP10s at Summit Point in March because of this. Now after a couple years of struggling with this car trying to drive it passed its limit (but below mine) I dial it back a tenth or two and make sure the ESP light is not flashing through any of the high speed turns. If it is, the car won't let you go any faster and you're just chewing up brake pads for fun. This is one of the many reasons I'll be getting out of the GTI and into a proper track car as soon as funds allow.
Lastly, allow me to plug the Audi Club and say if you're looking for a great group of guys to hit the track with, check out NEQClub.org There are a lot of guys from your neck of the woods who come out to Watkins Glen, Lime Rock, and Tremblant. Edit: And again, if your car is an MKVI, they've got some electronic braking flimflammery that wasn't going on with my 2006 MKV on the track. I haven't dug deeper enough to solve the problem because it's nothing huge, but the early MKVs felt better at threshold braking than the MKVIs do IMHO.
#15 |
Touring Car Newbie
Verrry interesting. Yeh, mine is an MK6. I've previous tracked an E36 M3 and then a SpecE30 and i am pretty amazed at how much i can trail brake and point and shoot this car. I thought it was FWD, but it probably is the "hand of god". Do you think it activates front wheels as much as rear wheels for stability management? I didn't realize the MK5s and MK6s were different in this regard. Do you run with ESP turned off? With it turned off (its just slip control that turns off) the light on the dash steadily blinks. Will the light behavior change when its using ESP?
I've done a few events with ACNA and they've always been top notch. I used to live in Raleigh and VIR was my home track. Miss it! If only they made a BRZ/FRS with another inch of headroom... ugh.
#16 | |
FIA World Rally Car Champion
![]() Drives: '07 Candy White GTI DSG Join Date: May 2008
I was looking at that flyweight BRZ, too, but also have a problem fitting into Japanese sports cars. Apparently, Germans are taller. Swedes, too, based on my Volvo. Boxsters have a lot of headroom, BTW. If I were you, I'd invest in a bottle of that temperature-indicating brake paint. It will give you a piece of data that would be very useful to your brake supplier when making the compound choice.
Dynjo Dyno, with a typo! |
#17 | |
Touring Car Newbie
I guess one solution is to just throw giant brakes at the car and let it do its thing. I don't like that its helping me though, i'm doing HPDEs to learn how to drive and this is dumbing it down for me.
#18 |
Rally Car Champion
![]() Drives: 2008 Candy White R32 #702 Join Date: Aug 2010
Car - 2008 MKV Golf R32
Weight - around 3300-3350lbs Power - 240hp (estimate) wheels Rotors - Racing Brake 2 Piece Rotors (front/rear) Calipers - ATE Super Blue with Tyrolsport brake stiffening kit Brake pads - Carbotech XP20 (f) Hawk HPS (r) Lines - USP SS Wheel size - 18x8.0" ET45 Enkei PF01 ~18lbs Cooling - dust shields removed all around Fluid/Misc. - ATE Super Blue Fluid Tires - Nitto NT01 225/40/18 Tracks - Willow Springs, Streets of Willow, AAA Speedway Roval, Buttonwillow Experience level - Frequent road race(High Intermediate) I just added a BBK caliper made by Racing Brake which I'll be testing at the track in July. The setup above has worked wonderful without any issue.
"The VR6 was an orchestra of well-tuned cylindrical delights." - jalopnik.com |
#19 | |
I try to do what you suggested earlier. That is, drive hard, but not so hard that the TC light is on too much. I figure if that light is just twinkling a little, that car, at that moment, in that situation, is going about as fast as it can. Isn't that exactly where you want to be?
#20 | |
FIA World Rally Car Newbie
![]() Drives: 07 GTI DSG Join Date: Dec 2009
And R compounds certainly have a sweet spot temp wise to get 2-3 best laps. |
#21 | |
#22 | |
| Thread Tools | |
