PROBLEMS: RNS510, Bluetooth, Steering wheel buttons, airbag fault
DragonzBreath
Perth, Western Australia
mkV 1.9 TDI
Hey Guys,
I drive a MY05 Golf 1.9TDI, manual, with a lowline dash. I've got a few problems I'd appreciate some help with.
Problem 1.
A couple of years ago I retrofitted a RNS510 into my Golf. I have not been able to use the buttons on my steering wheel since. That is except for the volume control. After one of the RNS510 firmware updates my battery started to drain over night, so my Dad (a VW tech) upgraded the CAN Gateway. I hoped that the buttons on the steering wheel might work after this. They do not.
My suspicion is that the RNS510 may be coded for a highline dash and steering wheel buttons, but I'm not an expert.
Problem 2.
At some stage, before or after the RNS510, I cannot remember. I also had a Genuine Standard Bluetooth Kit fitted. The Bluetooth works great, but again, the steering wheel buttons to pick up and hang up don't work. Could be related to the above, I'm not sure. I have to look at the phone to see who is calling and to pickup.
I'd like to see who is calling on the RNS510. Is this a feature of the premium bluetooth kit? If so, could I purchase the unit and plug it straight into the wiring harness from the standard unit?
Problem 3.
The airbag warning light came up on the dash about 12 months ago. The fault was reset 9 months ago, and stayed gone for about 3 weeks. The light came on when I closed the drivers side door one day (engine was running). I'm guessing either a wiring fault, or a sensor fault. I've read about connection issues under the driver seat, but don't know whether that is my issue or not.
Problem 4.
I mentioned above that I have a lowline dash. Is it possible to retrofit a highline dash? If so, is it expensive/difficult?
I'd like to have the RNS510 integrate with the dash as it does in newer generation VW's.
I ordered (direct from RossTech) a HEX-USB+CAN Interface, which was shipped same day (very impressed). Anyhow that should be here by the end of next week, so I can provide some diagnostics to anyone willing to help.
ALL help would be greatly appreciated.
Tr!tan!um
Schnellen geher!
AlAbAmA
2008 GTI, white
Often an airbag fault it triggered in the headunit removal process. I believe this is from unplugging the airbag light inside the dash, but dont quote me. However, the way you describe it, they may be unrelated.
DragonzBreath
mkV 1.9 TDI
Thanks for the reply, I don't have an airbag light where my head unit is. But from the VCDS fault log (attached) I think that the crash sensor in the drivers door is either faulty, or there is a short?
I've actually cleared all DTC faults and then taken the car for a 10 minute drive. I'll attach the fault log after that too.
  • VAGCOM - 20120911@1933.txt
  • VAGCOM - 20120911@2033.txt
