supertanch
- Fremont, CA
Everyone knows that the GTI's spindle is probably the weakest part in the car's suspension links. Once the car is lowered the front control arms will drop below level and you starting to lose camber.
Audi TT-S/TT-RS uses basically the same platform as GTI but with alumnium control arms and spindle, the design of which not only reduces the weight but the ability of a lower mounting pointing compared to GTI's spindle provides a leveled control arm on lowered cars. The control arms also widen the front track by about 1.5 inche each side which gives more stable control.
Recently 034 motorsport helped me on this conversion, it took about 2 days as it's the first time they did it as well. They had to experience what are the additonal parts needed for the conversion, it turns out that one will also need the TTS tie-rod assemblies.
The control arm along with the spindled lowered the car about another 1 inch, and I need to raised the front suspension to avoid rubbing.
Front camber is maxed out at 1.8/1.9. This is the max I could achieve without the camber plates.
Parts needed: (034 motorsport helped me ordered all the parts, and they did an excellent job on the installation!)
8J0 407 253 D Housing left
8J0 407 254 D Housing right
8J0 407 151 D Control Arm
8J0 407 365 Ball Joint
8J0 407 366 Ball Joint right
8J0 407 175 Ball Joint locking plate left
8J0 407 176 Ball Joint locking plate right
Tie rod end (both left/right)
inner tie rod
(sorry no part numbers for above)
Machining is needed on the control harm mounting point.
Here's some pics of the suspension parts I took last week (pardon me with the cell phone pics..)
Driving impression:
Normal road: There's no change that I've noticed, the car feels pretty much the same as before.
Track: Went to Laguna Seca last Sunday, and proved that these parts well worth the money.
Turn in is much more crisp compared to before, and the car gave a much more neutral feel than mild understeering. I do have H&R front/rear swaybars with front set to soft and rear set to hard.
Mid corner power puts down much easier and smoother, on turn 6 I need just mild braking then the car can fully utilize the dip to carry more speed. Coming out of Turn 11 to the long straight I was able to put down the power earlier and gained more exit speed.
Also gained one second on my personal best from 1:48.9-1.47.9. Despite the tires are not good and I had a lot of power issues in the day, I'm very satifying with the time.
Unfortunately one of my coilpack was cooked in the third session and ended my day. I'll be going back again this coming Saturday and enjoy the mods more.
Many thanks to 034 motorsport of helping me on this project, and if any GTI owners in bay area wants to do the same mode, I highly recommend them for the parts as well as the installation.
inner tie rod
Driving impression:
