Mantus
- Huntsville, Alabama
So I recently had Audi TT front lower control arm bushings installed. For those who don't know, our OEM bushings have two large holes and two slices taken out of the rubber, to increase the ability of the control arm to move around in the bushing. While this may increase ride comfort, it hampers handling and contributes to the GTI's wheel hop problem. The Audi TT bushings are just solid rubber, with no holes.
I decided to go with rubber over poly bushings since I have been hearing bad reviews about needing to grease poly repeatedly, and I wanted a no-maintenance solution. After my installation, I noticed that the front end felt much more planted, and turn-in was extremely tight. Wheel hop was noticeably reduced. With both a transmission mount insert and this mod, my wheel hop is probably 25% of what it used to be. It's not completely gone, but it's good enough for me, and I don't want to do full engine mounts. Also, I'm currently breaking in a set of Michelin PSS tires, so once they get settled, it will probably be even better.
In comparison, I feel like the transmission mount insert did more for wheel hop (and solved the crazy engine lurch I was getting with my stage 2 tune), but also had more negative effects (vibration at ignition, idle, first gear, and reverse). The most interesting impact of this mod, though, has been steering feel. I wasn't expecting much, but I was pleasantly surprised. These new bushings take a lot of the softness and play out of the steering, leaving it with a muscular, sporty feel. Honestly, this is the way this car should have felt all along.
Finally, there appear to be no negatives to this mod. If there's more road vibration coming into the cabin, I can't tell. Maybe that's because I actually like to feel the road a bit. Either way, I highly recommend it. Be warned, finding the bushings is a bit of work - you can order the full TT housing for ~$120+shipping, but you have to press the bushing out of the TT housing and into yours. You can order the bushing itself for super cheap (~$15), but only from vendors in the eastern hemisphere. In the end, even if you have to pay ~$45 for shipping (like I did) it's still a good deal.
