Subd for results. Be sure to post pics of the drop along with your review, vegas.
aw614, I have the Neuspeed Sports, paired with Koni FSDs. These springs paired with the FSDs give a drop that's very similar to my old H&R Sport springs/ Bilstein B8s but with less rake. They ride better than stock, and sooooooo much better than the H&R/ B8 setup, but they greatly reduced my handling and straight line traction since they are too soft and sloppy to control body roll, dive, and squat. I bet you have better ride control and handling with your DGs. When new, the progressive Neuspeed springs felt way too soft on the initial part of their travel, leaving the car tippy and unsettled-feeling, and the car sat up much higher than I expected it to. But they are so soft that the softer coils of the progressive spring compressed away to nothing after about two years as the car settled much lower during that time, so the super-compliant ride goes away as the coils stacked up, leaving me with a car that neither handles well nor rides all that great. I rate the overall experience a C+, but I'm much happier than I was with the brutally stiff previous H&R/ B8 setup.
In any case, I'm not sure how much my shitty ride with the H&Rs was because of the spring rate or the too-stiff Bils, and I'm not sure how much my shitty handling with the Neuspeeds is due to the soft springs or the sloppy-ass FSDs. In both spring/ damper setups I've had, I wish I had gone with Koni Sports instead of the MKV B8s and the Koni FSDs; it's so nice to have adjustable dampers that you can use to compensate for deficiencies in ride or handling caused by your spring choice.
