I just ran an auto-scan on VAG-COM for the first time and it picked up three errors. :frown:
The descriptions don't look too serious to me, but I note the fault code priority is 4, which the VAG-COM manual describes as "the fault recommends an action be taken, otherwise driveability might be affected".
Is this cause for alarm?
Here is an extract from the report:
Friday,02,May,2008,16:19:50:10186
VAG-COM Version: Release 704.1
Data version: 20071016
Chassis Type: 1K0
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 47 52 56
VIN: WVWZZZ1KZ8W080268 Mileage: 7930km/4927miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
Address 46: Central Conv. Labels: 1K0-959-433-46.LBL
Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT
Component: KSG PQ35 G2 020 0204
Coding: 819002085103087F2D04840570085AC690BC00
Shop #: WSC 00000
Part No: 1K0 951 605 D
Component: LIN BACKUP HORN H07 9001
Part No: 1K0 951 178 A
Component: Neigungssensor 003 0203
Component: Innenraumueberw.003 0203
3 Faults Found:
01135 - Interior Monitoring Sensors
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 4
Fault Frequency: 1
Reset counter: 167
Time Indication: 0
00323 - Vehicle Inclination Sensor (G384)
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 167
Mileage: 7590 km
Time Indication: 0
Date: 2000.00.00
Time: 21:25:14
01134 - Alarm Horn (H12)
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 167
Time Indication: 0
Chassis Type: 1K0
Shop #: WSC 00000
3 Faults Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 167
Time Indication: 0
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 167
Mileage: 7590 km
Time Indication: 0
Date: 2000.00.00
Time: 21:25:14
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 167
Time Indication: 0
