DSG not farting anymore and it ain't Beano!
A3_8V_BLACK
Brazil
AUDI A3 8V
There is like 7 or 8 of them total if you go into Auto Trans and select "Basic setting" you will see these 4 settings that need to be reset...
-Calibration of synchro-points
-Reset clutch characteristic curve
-Resetting of all adaptation values
-Start double clutch fast adaptation
Your transmission fluid must be between 30-100°C to complete these procedures too. I had this exact same issue too a few weeks back and it makes a night a day difference... farting on every shift again lol. Really improves lockup, the reason its likely not "farting" on an upshift is because the clutches are slipping slightly. If you have the Performance Package, make sure you reset your VAQ diff calibration while you're at it too.
Reopening the post!! Does anyone still have this problem?? Mine farts very little, sometimes yes, sometimes no!!!
I confess that I'm afraid to do the "Resetting of all adaptation value" procedure, because a message appears saying that there may not be a reversal if there is a problem!!!
deleteaccount
Spokane
GTI Sport
That the problem occurred AFTER the service is suspicious. I would check the oil level just to verify it's good. It requires warming the car up and watching the amount of "dribble" from the "snorkel" hole in the system. I could see a situation where they didn't fill it correctly. What we usually see as coincidence is actually a cause or an effect from such cause. Since it was serviced, start by confirming service was done correctly.
A3_8V_BLACK
Brazil
AUDI A3 8V
Hi, I checked the oil level coincidentally 1 month ago!! Everything was ok, on the level!!
I did the procedure
-Reset characteristic curve clutch
Looks like it improved the farts in high rotation!! But what I also noticed, is that the farts stop doing after accelerating, for example, from fourth gear from 2000 to 7000........ It seems that it gets hot and the clutch kind of slips, but that only when changing gears , if I pull from 1000rpm at full load it doesn't spin!!
A3_8V_BLACK
Brazil
AUDI A3 8V
Watch this video if you can understand what I'm talking about!!!
  • VIDEO-2022-02-05-20-30-02.zip
zepelin
Romania
VW Golf 7 R variant
If I have ECU and TCU tuning on the car and I changed clutch to a stage 1 850NM and do the above settings do I get back the "farting" and still keep the TCU tuning? The mechanic said they have a backup of my tunned TCU but the change of gear makes no sound, I have almost no engine brake and my launch control does not work (rpm wiggles between 3000-3900 but does not stay constant)
zepelin
Romania
VW Golf 7 R variant
I went back to the shop where I changed the clutch and remade all 4 steps mentioned above (with an Launch tester that had all steps individually) and after 100km of adapting now the car acts like it should be.
!! Big mention : after doing the casual adapting (changing gears, small brakes and reverse) there is also the need to start with full gas (kickdown). Only after doing this I started to get the noise from the exhaust valve opening. This step was missed in the first adaptation that the mechanic did (he was afraid to do it on someone else car) .
