Exhaust valve open
wulliebhoy
ZE2 9HL
MRK7 Vw Golf R
Wonder if anyone can help? I recently changed my exhaust to a miltek and noticed my offside valve was in the open position the whole time, so last night i changed the valve and it was working. Today i started the car up and left it running as it was cold for about 5 minutes. I then decided to check the valves and it was in the open position again and wouldn't close when i put the car back to eco mode but the nearside one was closing and opening as it should. So I was wondering if the car reaches a certain temperature will the valve stay open? Im guessing not but thought i would ask
The Fed
Old Guys Rule
Florida
Unless operation in Eco mode is something strange to me, they're always open at idle. If you have DSG, listen for the exhaust changing tone when shifting from Park to Drive and back again at idle and stopped. Unless it's different than my 2016 US version, temperature doesn't make any difference in operation. You can try checking the voltages or use a bore scope to watch it work while someone works the shifter. When shifting from P to D, the flaps should momentarily close then open again as a test since you're still at idle. Possibly, one sticks when it's cold or hot because the Miltek wasn't assembled correctly, and the flap is binding. Or maybe the plug or wiring has a problem. Can you remove the motor and watch it work out of the exhaust? That way, if everything operates fine the flap or shaft is binding. If you have VCDS you might get a code.
wulliebhoy
ZE2 9HL
MRK7 Vw Golf R
Its the manual my friend. When you have the car in ECO mode the flaps are closed but in race mode its open. I will take it back to garage and have a look again. Maybe it need to be programmed or something. I didnt tbink the temperature would be the cause i was just wondering, its really annoying me 🤣. Thanks for the reply my friend really appreciate that
Charlotte.:R
Charlotte
'18 Golf R 6MT
Wondering if the valves were not transferred to the new exhaust and installed correctly. The fitment of the passenger side on my Borla was suspect, but I have them coded always open so I didn't care.
scrllock
MI
Only have a single valve now, but IIRC that's normal unless you have them coded differently. One of them will be open and the other will stay shut, after re-starting the car or in eco/comfort mode.
The Fed
Old Guys Rule
Florida
I did see elsewhere they are usually closed in Eco mode. I have coded open all of the time. I'm used to the drone. In cold weather it's fairly loud.
wulliebhoy
ZE2 9HL
MRK7 Vw Golf R
I think there both working now, thank you for replying to my post. Love the sound of the milltek its sweet 🤣
  • Like
Reactions: krs
RS4DuWalker
Dallas
‘12 MK6 GLI Autobahn
Hi All! I have a similar question, concerning the flaps on the exhaust. I hope this is the best thread to post my question. I have the AWE switch path exhaust with the APR turbo-back downpipe. I’m concerned that the valves aren’t opening and closing on the AWE system. The valve for the mode switching from comfort/normal/race is working. Usually, I can put it in race AND open the valve on the AWE switch path with a separate fob. Is it possible that the valves are stuck because of carbon buildup? Possibly the actuator isn’t working? What would be your process of elimination? I’m hoping to avoid taking the exhaust off to find the problem.
Also, I’m getting some pinging noise on the passenger side exhaust. Is it possible that one of the flaps is loose and pinging inside the pipe?
I really appreciate any help. This car was a friend’s who passed away and I didn’t want it to end up on carmax or Autotrader, so I’m learning a lot about what all he did to the car.
The Fed
Old Guys Rule
Florida
I don't understand, because if the car's ECM is controlling the flaps, how is the Switchpath also able to open them? I would need to see how it's wired, because I thought with Switchpath, only the remote controlled the flaps and the ECM is not in the loop.
RS4DuWalker
Dallas
what you are describing is what it says on the website but the car seems more aggressive when you combine the AWE remote and race mode on the ECM. I believe the remote is an option he added. If it is in race but I don’t use the remote, it’s not as loud. So, when I put it in race, should the flaps automatically open or is that no longer part of the loop? If the ECM isn’t part of the loop anymore, could that cause damage, if I don’t use the remote to open the flaps? Thanks for the reply! I included what I could find for the remote.
