DarkX
Your Boss :P
- In a room with the door locked :P
- GTI ED30 DSG
Last Monday I finally decided it was time to say farewell to stock map and I must say it was a brilliant move! Changed my DV and got Revision D installed for peace of mind. Mine was in pristine condition when we pulled it out, but being diaphragm type there would always be a risk especially after remap. So now this new DV as you all know addresses the issue far more reliably.
As soon as we installed the software, we selected setting 9.6.9 which stands for boost.timing.fuel (100oct RON only - US equivalent 95) then we changed DV and got outside for testing. New software hadn't even fully adapted yet and the car boosted 1.76 bar (25.5 psi) over. According to the mechanic it's one of the best stage 1 ED30's they've seen. Using only top class fuel and babying the car since day one (warming up, cooling down, servicing, oil) were deciding factors to what came as music to my ears.
So far I've travelled around 200km and have had 3-4 cold starts, so I must be pretty close to having the software fully adapted. When that happens, I will be seeing around 310 to 315bhp and 420nm of torque without a single bolt on! :happyanim:
Now the DSG. Well I have not installed a DSG flash, but I have to say that it has also improved, dramatically! No more jerking at low speeds, gear changes appear to be a lot smoother. I mean I can't be wrong the difference is more than obvious. So I'm not sure if it's worth the money to have a DSG reflash, I mean if it's only for somewhat faster shifting I don't care that much for now. Maybe I'll do it later on when I go stage 2 I dunno. Your thoughts?
Also my rev limiter has gone up by around 200 rpm, so now I am able to shift at around 7100 to 7200 (compared to previous 6900). And the best part is, that it actually works! I feel this constant surge of power all the way to 7000 rpm and the next gear is always so strong, what a kick in the back feel that is!
In a couple months I'll install the fully ceramic red intake by NEUSPEED because I really love the sound it makes when you let off the gas and of course being fully ceramic it provides extremely low intake temperatures. This one is bolted straight onto the turbo. :headbang:
