I figured it was time to start documenting the build progress and next steps for my MK6 GTI.
It's a 2010 manual transmission two door base, in United Gray... The end goal of this build is 800 wheel on pump/meth and 1k wheel on e85/meth. Don't ask why...
To jump start this process I recently purchased a 2007 A3 3.2 VR6 which will be used for the drivetrain swap. I'd like to run a DQ500, however I am still undecided and may toss in a 'built' 02M... I've read a few DQ250's are still functioning past 850nm, but I'd rather have something a bit more bullet proof.
This thread will log the up's, down's, and everything in between.
Here is the current form/configuration:
Engine:
Transmission:
Suspension:
Brakes:
Wheels/Tires:
Exterior:
Interior:
Pictures (old to new):
Before the brakes/flares/wheels install
After the brakes/flares/wheels install
Engine:
APR K04 Kit
APR Downpipe (cat removed)
APR Catback System
APR Intercooler
ECS Exhaust cutout
IE Catch Can
FluidAMPR Crank Pulley
Neuspeed Charge/Discharge Pipes
Synapse Diverter Valve
Snow Performance Stage 3 Meth Kit (Dual Nozzle)
USRT 2.25 Gallon Tank
Transmission:
SouthBend Stage 3 Daily
Peloquin LSD
APR Full short shift kit
APR solid shifter cable bracket
BFI Torque Arm Insert
Suspension:
APR sway bars (front/rear)
NGP Type One Coilovers
SuperPro Control Arm Kit
SuperPro Ball Joint Kit
TyrolSport Deadset Kits (Front/Rear)
EuroSport Rear X-Brace
Brakes:
Porsche Cayenne (18z) Front 6 piston calipers
Racing Brake 2 piece rotors 355mm
EBC Red Stuff Pads
Front R32 Stainless lines
Custom Rear BBK bracket setup
Porsche Cayenne Rear 4 piston calipers
Stoptech slotted rotors 350mm
R8/Brembo parking brake caliper
Rear R32 Stainless lines
Wheels/Tires:
Enkei RPF1 18x10.5 et15
Toyo R888R 275/30/18
Exterior:
Voomeran MK7 full flare set
Flow Designs full splitter set
MK7.5 GTI (facelift) headlights
R20 tail lights
ECS Tuning Carbon rear spoiler extension
Clear side markers
US Millworks front plate bracket
DeAutoLED three way fog LED's (white, yellow, strobe)
DeAutoLED full interior LED Kit
DeAutoLED license plate LED's
DeAutoLED reverse LED's
Interior:
Podi boost gauge
Seicane Android radio
Sport Shifters custom shift knob w/surround and boot
Sparco QRT-R seats w/sliders and bases
Sparco 4 point harnesses
Autopower 4 point bolt in cage (w/options)
Eurosport Rear X-Brace
