I used ODIS tool to flash the Q revision.
Don’t know much info about the Kufatec tool.
If the oil temp sensor is installed and connected to the ECU & Cluster then let me know the existed SW version you have.
Address 01: Engine Labels:. 06F-907-115-AXX.clb
Part No SW: 1K0 907 115 R HW: 8P0 907 115 B
Component: 2.0l R4/4V TFSI 0020
Revision: 5BH16--- Serial number: VWX7Z0G83NA8OV
Coding: 040300101C070160
Shop #: WSC 66565 257 00032
VCID: 354FD8585CDD5EECC7-8060
1 Fault Found:
000054 - Oxygen (Lambda) Sensor B1 S2: Heating Circuit
P0036 - 004 - Malfunction / Open Circuit
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 178741 km
Time Indication: 0
Date: 2000.00.00
Time: 08:06:53
Freeze Frame:
RPM: 759 /min
Load: 18.4 %
Speed: 0.0 km/h
Temperature: 87.0°C
Temperature: 45.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 13.462 V
Readiness: 0110 0001
I don't "know" if the sensor is actually installed in my MK5 GTI, since I don't know where to check the sensor.
Is your copy of ODIS a genuine one or a clone? I'm trying to determine if the ones I see on eBay, can do software updates to the modules themselves.
