UPDATE: This was not the fix...sigh.
Alright so I know what it is.
Front sway bar brackets are the culprit. I have the APR (Hotchkis) bars and had the updated brackets sent to me. Problem is, the new brackets also require new washers as the stronger brackets leave less room for the washers sent out with the older brackets. So the updated brackets are installed, but I'm using the old hardware. Modified the larger washer so that it would fit within the sizing of the new bracket, but the washers on the rear side of the bracket are kinda toast from use I suppose. So much that I couldn't torque them all the way down without the bolt being slowly pulled through the bracket and spacer. Awesome. Now the car drives even worse as, over time, the bolts have come loose and I haven't had the time go crawl under the car again to tighten them until my replacement parts come from Hotchkis.
I've just about had it with this whole ordeal as I've been dealing with it since July (maybe June) and I'm seriously considering just buying another front sway bar to get away from this crap. So yea. That's the update. Frustrating.
Oh and I switched back to the stock end links because the custom adjustable ones I built were rubbing the passenger side axle. No bueno.
