You clearly don't know what rms means do you... That sub's rms is 450 ish its max is 1000. You never want to push a sub close to its max because you cut the life of the sub and you get destortion from over exerting it. You can even damage the amp pushing it that high.. An alpine amp should last longer then 2+ years... If the sub is dual 4ohm then i recommend Alpine's MRP-M500 (at 2ohm it pushes 500) great amp and price. Perfect match!! and make sure your running 4gaug for that much power..
Yes i am very aware of that. I typed it while i was thinking it, my mistake, re-edited. If im not mistaken i have a m750. i can confirm once i take a loot at it i forgot exact model.
And i believe its 4ohm, oh and yes the sub is capable of 600Rms. correct.
i took it to my local audio shop, and he took a look and he he confirmed. He checked everything.
Is it a w6v1 or v2? Also, are you sure that the amp is dead? Did you do any tests to rule out other factors? I'd hate for you to spend money on a new amp if something else is the problem.
He advised me to take out the fuses and leave it out, its possible that the amp could reset itself. Havent gotten a chance to plug it back in.
