iiCaptain
Hello again, I've had this issue for a while now, it seems as though it's been getting worse. On the highway my steering wheel shakes back and forth at 70+, and gets worse with speed and throttle input. However it still shakes when coasting in gear and in neutral. What's weird is that it only shakes with light steering input. If I make a deliberate turn, there's no shaking. If I let go of the wheel (no input), the shaking almost stops entirely. It only occurs when the road is slightly tilted requiring a small input to the left or right to go straight. No obvious difference between left or right.
I started noticing it on my winter tires (stock rims) last year, was very rare and almost never experienced it. Then I put on my summer tires and it got more noticeable. I attached pictures of the numbers on the back incase they're useful. They are forgestar f14s. It feels as though the issue is getting worse. I am almost certain it's not wheel balance because I've swapped wheels front to back, and got unlucky enough with a nail in my sidewall causing me to replace my front two and the issue still persists.
I installed a dogbone insert not too long before this issue, and also turned on TSC. I also accidentally took it down some rough state forest roads in the UP at LSPR. Those are the only things I can think of, as it definitely was not happening prior to LSPR.
Done a lot of research and came up with nothing, thinking my next step is to check alignment. Just looking for more information/possibilities before I pay to check the alignment as I am in college and trying to save money if I can.
