This was taken from another forum where someone put up a reason why fuel was going into their oil while using a AT pump internals. What are people views on this??
""I don't think it's a failure of the seal per se.
My understanding is that due to the stepped design in the piston fuel gets in behind that step (due the the lubrication using fuel). Once the piston is on it's return stroke it is trying to compress the fuel. Liquid can't be compressed so the fuel has to go somewhere and it will inevitably choose the path of least resistance. Which in this case is past the seal.
So rather than the seal failing. It is being asked to do something it wasn't designed to, due to the step in the piston. So if Autotech re-designed the piston to be one diameter it's length then, in theory, this would solve the problem.""
Now if this were true, something to worry about?
