#1 |
FIA GT Champion
![]() Drives: ug 2.0t dsg pkg 2 Join Date: May 2007
Check Valves for Forge DV spike reduction mod
![]() i have a few extra of these. they are made from kynar housings, and viton diaphragms. both very heat and chemical resistant. instead of the help! check valves which i read were only rated to 15 psi, these are rated to 150 psi! they wont break.. ever, not to mention they flow much MUCH better than the help! check valve, and have more secure barb fittings. they are good up to about 25psi w/o zip ties. $7 shipped. Shipped to Canada is $8.50 dollars USD. paypal:i ran out of the valves for stocking, however if i can get orders of 10 valves or more, i will get more in and get them to you guys. for those of you who do not know what the forge spike reduction is, see this thread: http://forums.vwvortex.com/zerothread?id=3453564 Please keep in mind that i am merely supplying parts to do the spike reduction mod, and i am not responsible for any damage that may occur to your vehicle from doing so. the valves have been thoroughly tested. i will help you when i can with the install, but if you do not feel comfortable doing it yourself, or do not have the knowledge of how the forge dv replacement valve works, i suggest you find someone that knows how it works to do the install for you. If you guys would like, i can piece together the whole spike reduction kit for you guys and ship it out to you all in 1 package. This is $21 for US, and $24 shipped USD for Canada. I have very little left, but i just got some more so i'll get them out as soon as they come in. Last edited by vrsix kevin; 05-21-2008 at 02:37 PM. |
#2 |
FIA GT Champion
Let me give you guys an in-depth comparison between the help! valve and my valves. the clear valve picture here is the same designed as the one that you would receive, just different material, i ordered alot of demo valves before i found the best materials.
Help valve is the stained white/black colored valve. sorry for the grainy pictures. ![]() here you can see the construction between the 2 valves, the help! valve is made out of plastic that is somewhat flexible, although you might not be able to tell, the construction of the help valve is also not as high quality, there is some plastic flashing left from the molding process on the outside. ![]() here you can see the difference between the smaller side of the help! valve and the barb of my valve, as you can see the help valve is much, much smaller, and therefore flows less, this might have an effect on how fast your reservoir returns regains vacuum. ![]() and in this last picture, you can see the lack of barbs on the help valve! on the skinny side, the tubing would not fit securely without a zip tie, and even with the zip tie i was able to yank it off with little force, with my valve this doesn't happen because of the barbs. the 3/16" diameter of the nipple fittings work with the tubing that comes with the forge valve perfectly. Last edited by vrsix kevin; 05-14-2008 at 10:34 PM. |
#3 |
Touring Car Champion
![]() Drives: Mk6 UG GTI Join Date: Apr 2006
Where did you buy them from?
#4 |
FIA GT Champion
i got a bunch of them from a wholesaler ;)
all i will tell you is that if you buy one from anywhere else, you would be paying wayy more that what i am selling it for shipped.
Forge DV Spike Reduction Kits and check valves |
#5 |
FIA GT Champion
t
#6 |
Most Hated Hater...
I'll take one if you ship to Toronto Canada
thanks
P.Tien Team Bridgestone Tires/R Squadron North America Director/Co-Founder Never Drive Faster Than Your Guardian Angel Can Fly Bridgestone 2008 CW Golf GTi MKV DSG (Also sponsored by: KW Suspensions, Synapse Engineering, Euro Jet, OSIR Design, Unitronic, MOTUL Canada, Stoptech, AEM and Ignited HID) Bridgestone 1997 GT2 Wide Bodied Porsche 911 fully built Supercharged Intercooled 500hp (Also sponsored by KW Suspensions, Motul, EBS Racing, GTek Auto, Fabspeed and Ignited HID) www.shinzomedia.com |
#7 |
FIA GT Champion
you have pm.
#8 |
I'll take one, too.
#9 |
FIA GT Champion
you have a pm as well.
#10 |
FIA GT Champion
only 4 left.
#11 |
FIA GT Champion
3 valves and 1 kit were shipped out today.
#12 |
FIA GT Newbie
![]() Drives: 2006 Candy White DSG Join Date: Apr 2007
Can you explain what exactly the spike is and how it occurs? My car is acting weird since the valve, releasing pressure at weird times or holding boost when not heavily on the throttle. I'm not sure if this mod would help my situation or not....thanks for the input!
#13 |
FIA GT Champion
sorry i dont know that much of the technicalities behind it, all you might need to know is in the thread i linked to.
#14 |
![]() Drives: MKV GTI Join Date: Feb 2006
PMed you
#15 |
FIA GT Champion
valves are now on backorder, any orders that come in from this point on will ship out in approx. 1 week.
#16 |
FIA GT Newbie
I thought you had one left, why the refund!?
#17 |
FIA GT Champion
the valves i lost count of, but i could not track down anymore of the resevoir kits, looks like i bought them all.
#18 |
FIA GT Newbie
Are you getting more kits in soon? Just curious I'm sick of the valve not closing, or taking awhile to open! Let me know! Thanks!
#19 |
FIA GT Champion
from teh way it looks, it'll have to be a group buy of 5 or more.
#20 |
FIA GT Newbie
Thanks for your help, I just ordered myself the fuel filter
#21 |
#22 |
Lets start a groupbuy! Im getting 4 myself! Need 10 to complete the groupbuy!
1. etang789 2. etang789 3. etang789 4. etang789 5. 6. 7. 8. 9. 10. |
| Thread Tools | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Forge DV Spike Reduction Mod | NoRegrets78 | Engine / Drivetrain / Exhaust | 75 | 01-06-2009 02:37 PM |
| PCV with 2 check valves (EJ and Master valve) | rysskii3 | Engine / Drivetrain / Exhaust | 4 | 02-29-2008 08:20 AM |
| 20K Service | ketchupfreak | DIY + Maintenance + Tips/Tricks | 20 | 09-29-2007 01:50 PM |
| WORST Turbo Mod EVER - Check Out this Moron! | Kricket | Off-topic / Misc. | 15 | 09-16-2007 02:01 PM |
| Check out this cheap mod! | Wantagti | Engine / Drivetrain / Exhaust | 16 | 06-22-2006 05:37 PM |
