To the point
Car started hesitating when WOT few weeks ago (maybe once a week). At the time threw the P0087 P2293. Took it to the dealer scared of the cam follower but it was ok. They said I had also P2294 pointing to the hpfp but didn't do the job with them.
Changed later my spark plugs and the problem seemed to go away but came back again a week later. Same codes. Today I changed the fuel filter and problem still there. Still P0087 but now I get P310B. Weird 2293 is gone. The only way to get a 2294 is if I unplug the N276 (regulator valve) but it is plugged (don't ask how I found out XD).
No apparent problems on start-up or idle, only when pushing the gas. It's been very cold weather and today was very warm. No difference. Cabling seems fine.
Plotted few parameters (bought an OBDEleven for this, sorry I cheap out, but doesn't do too bad):
Not sure I choose the right ones (new on this). In the pic you can see:
To me the first time I push the gas after starting up the car, everything was fine. RPM up, HP up, LPFP duty cycle up but pressure (LP) same. When I let go the accelerator, one can see the LPFP drop duty cycle for an instant and then back to normal (50%). Note that it is something that happens even on the next "wrong operation" cycles. Then, when I step for 2nd time, things go wrong. HP seems to try to follow but then starts dropping and as such ECM asks the LPFP to work harder. LP raises immediately and never gets back. Only for an instant when I let go the accelerator.
So, who is the suspect here? I think the sensors are ok but somehow HPFP is not doing its job. Not sure why LPFP gets stuck high, though (obviously controller must be asking but why...).
So I got an HPFP and may put it tomorrow but wanted to save the money (return it) if this wasn't the case... I am just running out of weekend
Thank you everyone!
[2007 MKV (2L FSI)]
- RED: Group 1 - Field 1 - RPM (I divided it by 10 so it is easier to see)
- GREEN: Group 2 - Field 2 - Load (%)
- VIOLATE: Group 103 - Field 1 - Low pressure (bar) (I did some math on it to zoom in and make it more visible, so, don't look at the Y axis for values, just the numbers I wrote on the line)
- LIGHT BLUE: Group 106 - Field 1 - High pressure (bar)
- DARK BLUE: Group 106 - Field 2 - In-tank (LP) fuel pump duty cycle
Thank you everyone!
[2007 MKV (2L FSI)]
