zither99
amateur auto-x'er
- edmonton ab
Helloow!)
I have one question..
How many emblems of airbag needs for replace?
Thx
2
Helloow!)
Thx
yeah so how would i put a regular antenna in if i want my shark fin out?
same procedure but you would get the stock antenna from the dealer..
but what about that big square whole it leaves?
press and hold the right knob, first you will go into the regular settings menu, then it will go back to the radio, and then it will go into the service menu
The regular antenna (bee-sting type) has a square anchor on the bottom too. However, if you've got satellite radio, you're gonna need to keep you fin antenna!
thanks for the update ewoo, I get the same thing, but I get no am signal at all. I thought your ANT1 will be ON but just weak signal. I contacted tmtuning earlier and they said it should be enabled with vag-com somehow (I dont know how) and that it may not be connected right (i hooked it up just like the stock antenna). I checked with vag-com and there is a fault code, "broken circuit", as if the antenna is not connected. I dont really care about AM, although it would be nice if it worked
I thought your ANT1 was definitely on and just had weak signal, and mine was defective. But I guess these antenna's are just like this, oh well, i like the look of it better anyways.
Hi,
Could the dealer set it for the am band to work?
Did you read the whole thread?
Yeah I did - could it be done or not?
Thanks
No. If you need the antenna to work again, you'd need to put back the original one that your GTI came with.
