tranceporter
F**K YOU CAM FOLLOWERS
- NY | NJ
- '08 BMP GTI
cool
One thing to add, non-gti's dont have the top vent .. instead they have an odment tray.
Hi all,
I would like to thank everyone for the coolest DIY guide on the web about removing the stereo unit but I would like to make a question on a very silly thing. Do I have to remove the power supply from the battery before doing anything? If YES is there a possibility something goes wrong after putting all together and connecting back the power supply from the battery????
Please help me on that silly question. How safe is to work with the battery on and will it harm anything if I don't disconnect it before working?
Thank you very much again for everything!!!!
Thank you very much but I don't really understand when you say to disconnect the ground terminal. Do you have any photo to help me? I thought that the battery only has (+) and (-) poles and by just removing the two cord from these poles should do the thing. Is there anything else to unplug? Your answer though was very helpful. If you could please explain a bit about the ground terminal...?
Thank you
Ground terminal is an American term for the — connection on the battery. No need to disconnect them both, just the negative terminal will do.
You can install a double din unit in there. I have a single din center channel speaker and my kenwood indash unit in my car.
Man really good diy . now tell me me will u sale me ur stereo?hey guys,
trying to help as much as i can. here is to how you can remove your stereo.
it was suppose to diy ipod adaptor install, but the one we bought from mp3yourcar.com does not work they way they claim it should. so here are the instructions. DO THIS AT YOUR OWN RISK AND I'M NOT LIABLE FOR DAMAGES THAT YOU CAUSE TO YOUR CAR.
tools needed:
torx-hex and flat head screwdrivers
towel to put between your screwdriver and your car.
10mm socket
1. DISCONNECT YOUR CAR BATTERY using the 10mm socket. remove the tab right in front of the center top vent to remove the vent cover.
2. after removing the vent you are able to remove the torx-hex screw holding the vent switch and door.
3. with the vent switch and door removed you will uncover the two screws holding the top part of your center dash together. you are now able to remove the top partion of the your center dash including the center vents.
4. after the top part is remove there are two screws holding the bottom part of you center dash. remove those and you'll be able to pop the bottom of your center dash out using your flat head screw driver. BE SURE TO USE YOUR TOWEL ON THE HEAD OF YOU FLAT HEAD SCREWDRIVER. so you won't scratch your car.
5. last step is the removal of the four screws holding your stereo together. remove those and BAM you are done. putting the stereo back is just the reverse order.
