Vortec4800
- Chandler AZ
- 2009 VW GTI
There is one.......:wink:
Really? I looked a while back and only found really basic info on it.
buckets DIY of the inners is great if u want to add the inner tails as Parking and Braking Lights Only.
When I try the 00 00 00 0F 00 coding, it gives me an error and says "F" is not a valid code or something like that.
Not exactly true Mike. Depends on where you wire your supply voltage from. With this mod, you may need more than one supply according to which configuration you choose for the inners (hatch mounted) and the outers (body mounted).
After seeing this, was going for the full four ring tails and using the inners for tail and brake. Looks like I'll have to add an extra supply for the tails.
bump - did anyone find out if the outer ring can act as brakes too purely through VCDS coding? I just got LEDs installed on my inner tails and I'm looking at options for a quad ring mod. As I've wired my inners to the parker function on my outer tails, they're on the same wire as the outer ring of the outer tails (sorry if that sounds confusing) so if that can light up as brakes then I have full quad rings with full brake function.
Didn't want to wire my inners on to the brake function as on brakes only the centre of the outers and the inner tails will light up, with the outer ring still dim - not a fan of that look.
