WhiteJames
Fun Nazi
- Sydney
- VW Golf GTI MKV
Muller & Muller gave me a race car type of setup. Rear is a tad lower than front to add stability when hard on the brakes and at higher speed with more initial push into corners. With this ride height balance changed front to rear, rebound & compression set up on half/half, the GTI is oh so stable under brakes ... the whole car is stable. GTI is probably a bit too low for my personal taste, but I'm not willing to change atm, until everything settles. Probably low enough to attraction the wrong type of attention. As with the previous suspension, I don't think the rear will settle very much, if any at all (1-2mm). The front should settle at least 5mm. This is clearly evident in Jester_Fu's R32 with the HPA KW SHS coilover that has shown an easily discernable drop in ride height, esp at the front. Jester_Fu says ride height reduction via settlement was progressive for over 3 months. We didn't measure, but difference in ride height between GTI and R32 is not too indifferent.
Grip levels have definitely been improved threshold of traction loss higher again with extra miles. Almost feels like you don't need the awd of the R32 unless in very tight corners or wet/greasy conditions. Jester_Fu brought up an interesting point in that some of the stability control - brake force/anti skid software may not be intervening as much due to the stability of the chassis and anti-dive qualities now present ... who needs an anti-dive/anti-squat caster kit with this KW V3 coilover (or the NVH issues). Now that we have been on smooth roads, opening up the GTI a bit more, traction control device have taken a back seat. My computer read out at the start of the day was reading 5600km to service; by the end of the day, it was saying service now. The 5,000km 6 month service was due last week, so not sure if the new suspension setup has confused the computer/sensors or the extra kays in the last 3 days has triggered the upgrade to service. I purposely waited for service to have KW V3 settled in first, so as the computer can be reset if need be.
We had my neighbour Ray the last drive. After the drive, Ray was sold on the KW V3 for his R32. Like all KW kits ... it's very quiet, better NVH than stock ... Ray says like having no suspension at all, you just don't hear it. Ride is unbelieveably well considering the V3 sporting intent and half/half settings (Ride on HPA KW SHS is much better though), and handles the rough stuff with ease, never bottoming out, crashing or banging. The previous setup would lean heavily on the outside front wheel when attacking a corner, a combination of softer suspension relative to sway bar stiffness. The front outside tyre would roll into positive camber, showing some tearing on the very outer part of the front outer tyre. The GTI doesn't lean as hard on the this tyre, resisting the positive camber roll during corning. KW V3 don't offer the super-repsonsive or terse ride of the Bilstein/H&R kits that really sporty drivers may prefer, can't imagine the Bilstein PSS10 set on half way would ride as good as the KW V3. Having said this, the KW V3 on half/half was notably terse on the faster flowing rougher B-grade roadways; for these types of roads the HPA KW SHS is preferable. Trade to Bilstein/H&R is some loss of connection & roadway feel in the KW V3 - always have the option of changing the settings in the V3 to create something similar to the PSS10/H&R; but the two will always differ. New pics are a big improvement.
Cheers
WJ
Cheers
WJ
