Connecting both antennas, iGO8 update and more
Updating the firmware on the WD6050 would be great, lots of fixes they could work on.
I just ordered two antenna adapters on eBay that should allow me to connect both to the WD6050. You can search on eBay for a "Antenna Y-Adapter Splitter 2 Female to 1 Male ISO - DIN", and I also got another antenna adapter like the one that ships with the WD6050. MRX knows what is going on. After some research, I think both AM/FM antennas are in the rear-window and top antenna is just for Sirius Satellite radio in the US. So in the US at least, pushing +12v on both antenna lines is the way to go. I can't wait to try it. Thanks MRX!
About the sound quality, I do hear electronic noise in the speakers. A small beat and an occasional chirp. It seems like 16 beats and a chirp repeating, it happens even when the engine is off and WD6050 is not muted (stops when muted). Also, turning the volume dial will cause more noises. It's not loud, but it would be nice to get ride of it.
iGO8 v8.0.0 that came with the system have no POI (Point of Interests) for North America. This was annoying, you can't search the local airport or restaurants. A quick search online and I was able to add all of the iGO8 POI. I looked at "
POI Plaza" web site, at first I figured it was great, but it's far inferior from the real POI that normally come with iGO8.
I also proceed to update to iGO8 v8.3.2.71348. It took a lot of fiddling around and the maps from iGO8 v8.0 are not compatible with v8.3. Still, I can confirm that it works well. I now keep both v8.0 and v8.3 SD cards in the car, just in case I run into trouble with v8.3. No major differences so far, but I expect new maps to be much better. I also added topographic & 3D building information, but have not seen what they look like yet. The device resolution of 480x234 is a bit odd, so it's not easy find the right iGO8 skins.
Y
