HowieR32
The Stooge-master
- Sydney, Australia
I have finally installed the kit after waiting 3 months delivery of it from Canada.
The KW SHS HPA sports suspension is a kit with dampers and springs. Only the sprins are adjustable in height. I went for around 10-15mm drop in height where it would settle down closer to 15. So far I haven't experienced aby major scraping although on tight corners the front guards would rub if I hit a bump mid corner.
I run 46psi all round and still the ride quality has improved with a significant reduction of the crashing one gets from ruts or pot holes on the road. I think on very small oscillations of the springs the dampers are underdamped as I feel the juggling on the car body when coming to a complete stop.
Overall the ride is very similar to oem with a sharpening of the steering response and better road surface controll. Smooth roads definitely feel smoother than before and body roll has reduced a tad.
I had them installed two days ago so the setup is still bedding in and will report more on the progress when I can.
The ride height is very nice, subtle and completes the look of the R32 with the 18" wheels filling in the guards nicely. There is only a fingers width gap on the front with almost no gap in the rear.
I am pleased with the results as I expected as much after driving RADIUM black R32. Thanks for the test drive!
Howie
Howie
