Dan GSR
- NY , Long Island
cuz the hot rotor will burn the pads, and it is possible to warp the rotor
Good tip. This is usually reiterated a few times in HPDE1 classroom sessions but it doesn't hurt to say it again.
As for the "HPS+" pads- there's no such thing, it's HPS or HP+ :biggrin:
mike2727 said:I switched to XP10's and XP8's in the rear, [...], they cannot be beat at the track as Meat said, they are the best I ever used at the track
mkvtg37 said:do you have to upgrade both the front and rear brake systems or can you just upgrade and improve one (if you are going big brake kit for example)?
good threads, Meat! you might also want to mention the Tyrolsport bushings :thumbup:
sure the XP10s can be beat: try XP12 or XP16.
with the kits i've seen, you don't need to upgrade the rear rotors. the rears do too much work as it is.
very good information... now here is a noob brake question:
I'll make a mention of them.
And one more note: as you've told me, the XP12's and 16's can be too much for street tires to handle.
even xp10s with street tires, the tires will overheat WAY before the brake pads will
