furbzzz
- New Jersey
damn it looks great! good luck!
you should've sanded it before staining. that way it is smoothe
I thought I sanded it enough? It is smooth.that too but it's a very classy idea!
I did. Maybe more?you should've sanded it before staining. that way it is smoothe
I shall!! :thumbsup:sick! use the other side so there is no chip out of the wood.
:thumbsup: Thanks for the advice man!then throw on some clear and sand then more clear then sand them more then sand and it will look like glass. did that to a bunch of stuff at work and came out really nice.
Great idea with the wood, but I would suggest using a nice piece of hardwood instead of the plywood you have there. It won't cost you anything to find a small piece like that in a remainder bin at a specialty wood store. It will look 100% better, I promise you.
If you ever want to put holes in thin sheet metal in the future, I'd recommend a set of of knockout punches like this:
http://www.harborfreight.com/knockout-punch-kit-91201.html
I purchased this set, and found that they needed a bit of sharpening with a fine tooth file... but a high powered drill + a conventional hole saw will do nothing but shred thin sheet metal. After a bit of sharpening these have worked great for me, perfect holes with no distortion. HF claims it will do 10ga... but I seriously doubt the bolts could withstand the torque needed to get through 1/8" mild steel. Should be perfect for what you need though.
whoop!I missed this. I like!
love how much this has evolved.
I can come over after work on Thursday, and we can work through friday to finish management/fronts.
