Widebody MkVer
Performance Infused Style
- Selden NY
no primer needed when u use the fusion paint by krylon.
OK this is real short and its a simple thing too.
Step 1) Using an old Credit card or not so used card (library card) slip the card into the gap between the logo and the hatch release as illustrated in figure 1.
Gently slide the card around the entire logo cutting all the double sided tape that VW used to hold it in place.
gently pry the logo from the backing. the logo is actually a separate piece from the back plate see figure 2
Back Plate is labelled A
Logo is labelled F
Why those letters you may ask BECAUSE I SAID SO!!!!!!!
then sand em both down prime em and paint em whatever color you want.
re-mount it using 3M double sided tape and take some pics and post em here
is there any way to just take off the emblem thats clipped in? or do you need to take out the backing/emblem as 1 piece and then unclip the emblem.
I have an 08 gti and I stuck a screwdriver in the crack between the badge and the black part behind it around the edge just enough to fit a credit card in there. Then with that I went around the edges until I could stick the card much further in and up and eventually got it popped off. It was stuck on there with clips.
